[SOLVED] deleting instances
I noticed a strange behaviour when I try to delete instances. So I took a look at the manual and found this:
Deleting the head cell of an instance in the middle of the layer will make its exposure cells be linked to the previous instance.
But if I try the same I only get this
The image got deleted, but the head just moves to the next exposure.
I guess I'm doing something wrong, but I don't know what.
Re: deleting instances
To withdraw the head an keep the good length, you must use Image > Exposure > Remove instance head.
Was is explained differently in the manual ?
Thank you a lot Elodie.
In the manual is only written "delete image" but not as specific as you told it.
Ok, thank you, I will proceed with the change so :)
