I'd love to see a water color brush that could be set to run the "water" down the paper. Painter has this feature and works very nicely, including paper porosity.
Would it be a feature others are interested in seeing in TVPaint?
Kathleen
Really drippy watercolor brushes
osX 10.7.5 intel iMac, i7MBP
TVP Pro 10.0.14
TVP Pro 10.0.14
Re: Really drippy watercolor brushes
Please can you post an image so we can figure out eaxcty what it is and how it looks like ?
- idragosani
The technique is basically getting the paper very wet and applying watercolor onto the water on the paper and then the water disperses or bleeds the colors (you can also tilt the paper and let gravity pull the color down). Depending on the paper and how course it is, you can also achieve different effects.The physical technique is shown in this video:
http://www.jerrysartarama.com/art-lesso ... pping.html" onclick="window.open(this.href);return false;
So it's sorta like how the sponge & knife work, although it would be more 'realtime', almost like a particle system kind of thing.
ok, Thanks ! I know what you mean now, it's just I didn't know the english technical name for all this.
Can you try the palette knife ? It's not exactly the same, but it's close.
Ok, we have some room for improvement here.
