Watercolor brush troubleshoot
jeaks
Post by jeaks »
Hi guys,
I use TVP 10 Standard edition and am very new to the software.
I don't know what all I did in my explorations of the software but my watercolor brush now looks like this pixelated mass of dots. T_T
I have no idea what happened =( =( What should I dooo????
system_specs: Windows 10 64bits , Intel Core i7, 16GB RAM, Quadro K3000m 2GB vRAM | Cintiq 13hd | TVPaint 11.0.3 Pro-64bits
Re: Watercolor brush troubleshoot
hi Jeaks and welcome,
check if you're still drawing in "Stroke" mode,
perhaps you've inadvertently switched it into "Dots" mode,
if it's not that, check the "Step" value, if too high, it will make gaps in the stroke.
Eric Scholl
Post by Eric Scholl »
Did you use it with your stylus ? Because this brush needs the pressure to work properly.
yes, it's a pressure sensitivity problem. You are probably using a mouse.
