Problem importing a jpeg drawing sequence
djsolomon
Post by djsolomon »
Hi I am having a problem importing a sequence of 28
Jpegs - they are 0nly 72 dpi so they are small
I have them in a folder on my desktop - and
I can't import them using "open"
I have also tried just dropping them into the
Drawing window ... And I get an error message
That says they jpegs can't be found ....
Any suggestions ?
Many thanks
Debra solomon
idragosani
Re: Problem importing a jpeg drawing sequence
Post by idragosani »
If you have an empty layer available, can you do it via 'import footage' in the menu when you right click the layer?
djsolomon
Post by djsolomon »
will try that now thanks!
debra
djsolomon
Post by djsolomon »
where in the menu is import footage?
debra
djsolomon
Post by djsolomon »
Is there an import footage menu?
debra
djsolomon
Post by djsolomon »
Finally after repeatedly dropping images into project window the import footage window opened-
thank you I Dragasoni!!!!!
my best from east village
debra
idragosani
You can also get the import footage menu by right clicking in the layers window:
Eric Scholl
Post by Eric Scholl »
You can also use this button in the new layer panel to import them in a new layer.
Import Layer.jpg (41.74 KiB) Viewed 17038 times
To import a sequence if they're named : image001, image002, image003, ... You just have to drag and drop the first image and all images will be imported.
djsolomon
Post by djsolomon »
Wow !!! THANKYOU !!!!!
I really appreciate the responses !!!
Many thanks !!
Debra
powerranger520
Post by powerranger520 »
i alse meet the same problem. but i solved it according to the opinion in this post. thanks
