Problem importing a jpeg drawing sequence
Posted: 20 Feb 2013, 18:44
by djsolomon
Hi I am having a problem importing a sequence of 28
Jpegs - they are 0nly 72 dpi so they are small
I have them in a folder on my desktop - and
I can't import them using "open"
I have also tried just dropping them into the
Drawing window ... And I get an error message
That says they jpegs can't be found ....
Any suggestions ?
Many thanks
Debra solomon
Re: Problem importing a jpeg drawing sequence
Posted: 20 Feb 2013, 19:14
by idragosani
If you have an empty layer available, can you do it via 'import footage' in the menu when you right click the layer?
Posted: 20 Feb 2013, 20:29
by djsolomon
will try that now thanks!
debra
Posted: 20 Feb 2013, 21:21
by djsolomon
where in the menu is import footage?
debra
Posted: 20 Feb 2013, 21:35
by djsolomon
Is there an import footage menu?
debra
Posted: 20 Feb 2013, 21:54
by djsolomon
Finally after repeatedly dropping images into project window the import footage window opened-
thank you I Dragasoni!!!!!
my best from east village
debra
Posted: 20 Feb 2013, 22:11
by idragosani
You can also get the import footage menu by right clicking in the layers window:
- Screenshot.png (28.83 KiB) Viewed 17072 times
Posted: 22 Feb 2013, 08:51
by Eric Scholl
You can also use this button in the new layer panel to import them in a new layer.
- Import Layer.jpg (41.74 KiB) Viewed 17048 times
To import a sequence if they're named : image001, image002, image003, ... You just have to drag and drop the first image and all images will be imported.
Posted: 22 Feb 2013, 14:03
by djsolomon
Wow !!! THANKYOU !!!!!
I really appreciate the responses !!!
Many thanks !!
Debra
Posted: 27 Feb 2013, 02:46
by powerranger520
i alse meet the same problem. but i solved it according to the opinion in this post. thanks
