cutbrush
Animaker
cutbrush
Post by Animaker »
I've just installed my copy of TVP on a new computer. Everything works fine, except the cutbrush doesn't show the image. It's there because I can stamp it down, but I don't see it on my cursor. I''ve tried changing everything I can in the cutbrush window to no avail. help ?
Haugse animaker
Re: cutbrush
check out this link: Toggle cutbrush visibility.
Setup a button that contains the following command: Key:Tools Brush:Toggle Display
(fixes several problems in the Android version but it definitely toggles the cutbrush visible and hidden in TVPaint in all OS.)
Animaker
Re: cutbrush
Post by Animaker »
Thanks for that tip. It got me going again. I wonder why I didn't have this problem when I first activated tVP. hmmmmm
Haugse animaker
Re: cutbrush
On the other hand you might just have to un-check Preferences/Display/Hide Tools Preview. You might have checked that by mistake.
I forgot about that option in the Preferences.
Re: cutbrush
Animaker wrote:I've just installed my copy of TVP on a new computer. Everything works fine, except the cutbrush doesn't show the image. It's there because I can stamp it down, but I don't see it on my cursor. I''ve tried changing everything I can in the cutbrush window to no avail. help ?
It's probably because the size of the brush is linked to the stylus pressure sensitivity.
In a such situation, TVPaint can't display the size of the brush.
