Every time I start TVP10 he is back on default? - solved!
Hi.
Is there something I have to press in order to prevent TVP always start as it starts for the first time (everything default)?
For example:
where are my recent projects?
why Keyboard shortcuts are not as I made them but default?
why subpixel is not selected, and I know I did selected it?
why my custom panel disappeared from menu after I restart?
etc..
is this common problem, bug, or something I have to deal with our administrator?
Please, let me know, soon
thank you, lovely TVPeople
For example:
etc..
TV Paint 11.5.3 Windows 10
Re: Every time I start TVP10 he is back on default?
Look into preferences under startup Tab; you probably have it set to Open Startup Panel. Choose last used configuration.
it is on last used configuration.
This is what I posted to our technical crew, because there may be configuration problem on our server:
I hope they will give me some answer tomorrow.Hi
every time I start TVP10 it's back on default.
This is very annoying since I have custom panels (now I have to load them again every time I start TVP), shortcuts (same) settings (same)
has anyone reported the same problem or I am the only one with this annoying issue? The only solution which is pretty ridiculous is to keep everything on and never turn off. Or? Thanks
And nothing helps, I tried many different startup setting, and I am just checking little thing, SupPixel, I am putting it on, but every time I start the program again it's off. My bet is - our technicians. So, we'll see tomorrow. I hope.
To me it almost sounds like it's behaving like a trial version which was never registered, although I doubt that is the case.
That's why I think it's something to do with server and licencing. This is definitely not trial, since I normally save, export and everything, and there is nowhere stated it's demo version.
But, in Europe most of the common folks sleep, unlike me, vampire, with tight dead lines so, we'll see tomorrow, if someone knows what's happening.
It's good to have across the Ocean friends to calm you back to in betweening!
That'll make you sleepy.
Re: Every time I start TVP10 he is back on default? - solved
Hi Paul, hi everybody
the problem was, strangely enough, that folder with preferences (in AppData) was by default Read Only. Well, no wonder that settings were the same all the time So, hopefully, it's only the problem with installation script we are using here, nothing to do with TVP.
Good to hear and thanks for the feedback.
