Viewing multiple Project or Zoom Windows
Posted: 04 Mar 2013, 20:51
by ndstephens
So when you click the keyboard shortcut 'M' or click the 'N' button in the Navigator Panel you get a new Project Window. It sits directly overtop of your existing Project Window. Is there a way to tab between multiple Project Windows that overlap each other? There are the tabs at the top for having multiple Projects open, but i can't find anything similar to swap between multiple Project Windows within the same project. I'm guessing right now that it's only useful if you have multiple monitors and can pull off one of the windows and put it on another screen for viewing at a different zoom or position. But maybe there's a shortcut i'm just not finding yet???
Re: Viewing multiple Project or Zoom Windows
Posted: 04 Mar 2013, 21:28
by Paul Fierlinger
Key command:
Key: Project Next
will that do it for you?
Posted: 04 Mar 2013, 21:36
by Svengali
try the Next Zoom Window command (cycles through two or more zoom windows)
Can be assigned to a button - Key:Zoom:Next Zoom Window
Can be assigned to a hotkey - Zoom / Next Zoom Window
I have used this recently to maintain several different Zoom intensities for the same frame: viewing distance, normal size and area closeup.
Posted: 05 Mar 2013, 02:39
by ndstephens
That's it, Svengali. The standard keyboard shortcut for it is Ctrl-Tab. Then you switch between the windows you've created. Thanks.
Paul, it's not switching between actual Projects i was looking for, but through the display windows (where your image is) that you've opened...for viewing different zoom settings, etc (look under View menu, "New zoom window"). But thanks for the heads up on where the Project:Next is, b/c i'll need that soon as well.
