Exporting problem
maryam
Exporting problem
Post by maryam »
Hello
Im on Mac 10.6.8 64 bit
My tvpaint 10.0.14 64 bit pro
I'm having a problem exporting my image as it should look and can't work out what is wrong!
So this Image is what I have in TVpaint :
Screen shot 2013-03-06 at 10.41.37.png (30 KiB) Viewed 9163 times
And this is what it looks in AE :
Screen shot 2013-03-06 at 10.42.31.png (51.3 KiB) Viewed 9163 times
I don't understand why the texture becomes dirty! I have tried exporting as Quickime on Animation Codec as well as PNG sequence.
They both look the same.
I also have another problem! So before when I chose the Chinese brush tool and selected 2 colours, it would start by one and the it would become the other color.
I don't get that any more. it says the same color! Can any one suggest how I can change it so it changes the color!
I appreciate any help.
Thanks
Animark
Re: Exporting problem
Post by Animark »
It could be helpful to have a screenshot of your export-settings. I cannot see big differences between the two pictures you have posted but it is difficult to compare them, cause of their different size. It would be also helpful to have those pictures of the same size dropped nearly together.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
maryam
Post by maryam »
Animark wrote:It could be helpful to have a screenshot of your export-settings. I cannot see big differences between the two pictures you have posted but it is difficult to compare them, cause of their different size. It would be also helpful to have those pictures of the same size dropped nearly together.
Sorry that they are in different sizes. I did screen shot.
The problem is the red texture.
The texture is a clean red in TVP but when I take it to AE, it has this dirty texture, it's like some of the color has become grey ish!
ematecki
Post by ematecki »
I think it is an alpha-premultiplication problem.
Try with the opposite settings for "Premultiplied Alpha".
maryam
Post by maryam »
ematecki wrote:I think it is an alpha-premultiplication problem.
Oh yes! thank you. That solved it.
Do you have any idea how I can fix my brush setting? :)
