im new working with TVpaint 10, and i have already some questions. i dont know if this is the right place to post them. so in case is not, i ask the moderators to change this conversation to the proper place.
Im trying to find out how many seconds my animation last. i could of course count tha many frames and devide them by 24 frames. i just wonder if there is an easier way to deal with this. if i want to make an animation of 1:30 min. i dont want to multiply 24 x (60 + 30).
any ideas?
questions regarding TVpaint 10
Re: questions regarding TVpaint 10
if you go to your Preferences, second tab is "Display", at the bottom in that tab should be "Timeline" with the option to check "Display Time Code". then you will see your timeline marked with time instead of simply frames.
is that the solution you were looking for??
great ! thank you very much! it does help
is there anyway to switch between both options without having to go to preferences as in quicktime, or adobe AFX
Use Key command:
Timeline: Toggle Frames/Time Code
