Light Table not working
Posted: 26 Mar 2013, 05:46
by JohnArtbox
I can't seem to turn my light table on... I've switched the lightable icon on in the timeline, and adjusted the lightable panel settings to display 3 frames on either side in red and blue default colours. However nothing shows.
I haven't used it for a while so it might be that I've missed something, but not according to the manual. I'm using tvp 10.0.16 64 bit windows on a windows 7 fujitsu tablet.
Any ideas??
Re: Light Table not working
Posted: 26 Mar 2013, 07:25
by ZigOtto
have you enabled the LT icon in the layer panel, at least on one animlayer ?
Posted: 26 Mar 2013, 07:38
by Paul Fierlinger
Is the zero in the LightTable activated (yellow)?
Posted: 26 Mar 2013, 07:40
by JohnArtbox
Yes I've toggled the lighttable icon to no avail. it goes from a small black circle to a larger yellow one.
- screenshot of test project.
Posted: 26 Mar 2013, 07:44
by Paul Fierlinger
Do you have the appropriate mode selected, Instance, being the most common one?
Posted: 26 Mar 2013, 08:00
by JohnArtbox
It was set to image mark... I switched it to instance and it worked. Thankyou for the assist.
Posted: 26 Mar 2013, 08:01
by Paul Fierlinger
You are welcome.
Posted: 26 Mar 2013, 23:33
by JohnArtbox
NB. I had also turned off frame 0 in the Light Table Panel...this seems to turn off the light table, which makes sense.
Posted: 26 Mar 2013, 23:41
by Paul Fierlinger
Notice that Zero does serve a purpose as a global slide. To not notice that it has been turned off is a common mistake, but if its name would be LT I think it would bring attention to itself.
Posted: 29 Mar 2013, 22:54
Paul Fierlinger wrote: but if its name would be LT I think it would bring attention to itself.
That makes sense
*or re-using the bulb icon maybe (light table is not the word used in French ^^)
Posted: 29 Mar 2013, 22:58
by Paul Fierlinger
Icons are always better and an unlit light bulb begs to be
turned on.
Posted: 29 Mar 2013, 22:59
exactly
