Hi. The only problem that I have with it is that it wont hide again, even if I´m using another tool.
It just stays showing the area where the camera is and the rest gets shaded. It wont let me see clearly the drawings on the current, past and future frames.
How can I leave or hide the camera view?
Thanks.
First, you might want to dim the black area, called in French (and here) Passepartout. You'll find this in the panel called, Display Settings (under "Windows". The second part I'm not sure of your question, because switching to a different tool does make the binding boxes go away. Is it perhaps that you have the camera off/on button turned on? It's the third button on the left of the video controls.
EDIT: I think I know what you mean now: To make the Pase... whatever disappear, use the key command:
Key: Display: Show Camera.
Paul http://www.slocumfilm.com
