Move up/down a layer (ignoring locked layers)
Lukas
Post by Lukas »
I'm trying to make 2 buttons to bind to arrow up and arrow down. That behave like normal 'Layer: Go up' and 'Layer: Go down' but they ignore locked layers.
So far I've not accomplished much... :(
I was hoping someone smarter has a clue, or maybe there's something out there like it. :D
  • Lukas Sketch Panel
  • TVPaint Pro 11.7.3
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Re: Move up/down a layer (ignoring locked layers)
Key:Layer:Previous Layer/Next Layer works that way here.
Lukas
Post by Lukas »
Paul Fierlinger wrote:Key:Layer:Previous Layer/Next Layer works that way here.
I was very happy to read your post, thinking my problem was solved, but here it still goes to locked layers...
"Layer: Go up" seems to do exactly the same as "Layer: Previous Layer"
Could it be a mac thing? What should the difference be between the two actions?
edit: I tested it on a windows machine (TVP 9.5) and it's the same there
What do you mean by "goes to locked layer"? ...where the action then stops? When I use these, they go through all the layers, the only difference being that in my custom setup I have added "shake" to next/previous layer, and locked layers don't shake.
Lukas
Post by Lukas »
Ah I see. So it doesn't really skip locked layers, but it gives visual feedback by not shaking the image so you know you have to press the button again?
That's the way it works by default, not that I want it that way, but good enough. I guess "locked" means "It won't even shake". But I use these buttons while searching where I am in a stack of layers so this is why I added the shake attribute.
Lukas
Post by Lukas »
I broke my brains getting this right... but it works now.
Here's a tvpx panel with 2 arrows that skip locked layers, if anyone is interested :)
LukasSkiplockArrows.tvpx
(131 KiB) Downloaded 155 times
Handy. I added the shakes though and in time I should find out if I like it to skip locked layers -- right now I can't see the advantage or disadvantage. :|
Thanks (nice icons). :)
