Inversion Problem
Paul MacManus
Inversion Problem
Post by Paul MacManus »
Hi everyone,
I'm new to TVP and having a problem converting a scanned pencil drawing animation to white on black. I'm thinking the best way would be to do a scan clean and then have a blacked out background layer and use a blending mode to make the pencil lines white on black but I've have tried all the blending modes,maybe I need to use a combination of line layers with different blending modes? Sorry if this is an obvious question but I've tried everything I can think of. I know I could use the fill tool but the animation is over 200 frames and I hope to use the same style in the future so a simple one click method would be ideal. Any help would be much appreciated, Paul
Paul MacManus
Re: Inversion Problem
I'm guessing i need a combination of the stencil tool or the preserve transparency with a blending mode but i'm hitting and hoping..
Paul MacManus
Managed to get it by duplicating the layer setting the top layer's blending mode to value and setting the background to none but course it won't export like that
Animark
Post by Animark »
Hi,
I would do it like this:
1. Scan Drawings in one layer
2. Use the basic scan cleaner (or FX - Color / Scan Cleaner) to delete the white space (makes it transparent)
3. Use FX - Stylize / Negative to change the color of the lines of the drawings from black to white
4. Set the Background Color to Black (or add an extra layer totally filled with black under the drawing layer)
5. Exporting the animation with background checked
That's it :-)
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Paul MacManus
Worked a treat! Knew there had to be a simpler way. Thanks a million Mark,was really getting my goat
or alternatively simply apply on your scanned sequence a Color/Curves/HSLO_FX with the Luma curve set inverted.
save the "invert-Luma" FX in the Bin to re-use it at the next occasion. :)
Paul MacManus
Thanks Zigotto,i'll remember that for again,my friend ended up doing the editting on Premier as he has much more experience and I think he used your method. You can see the finished film here(animation is just the first 20 seconds)
https://vimeo.com/66913084" onclick="window.open(this.href);return false;
