Keyframe Camera
jeremypurcell
Keyframe Camera
Post by jeremypurcell »
Hi
I am new to TVpaint, and I wanted to ask if anyone knew of a way to keyframe a basic camera position, I have a scene with four camera positions and I want the camera to hit a set position on a set frame, I'm not really sure how to make this happen with the time profile, or if it is even possible. I don't want the camera to stop on the frame but to continue to the next camera position.
Any help would be greatly appreciated.
Jeremy
Re: Keyframe Camera
If you use the camera tool located in the main panel, this topic should help :
http://forum.tvpaint.com/viewtopic.php?f=3&t=6645" onclick="window.open(this.href);return false;
Otherwise, you can also try the FX > Motion > Keyframer
artfx
Re: Keyframe Camera
Post by artfx »
With the camera tool, you need to drag out your progress profile really big. When scrubbing through the timeline, you will see a little blue line moving through the camera's progress profile. This is how you can know where on the curve a particular frame falls. Just make sure your keys on the curve line up with the blue line on the frames that you need. If your camera is not meant to stop, this should be very easy, though stopping the camera is very possible too.
Otherwise, as suggest by Fabrice, use the key framer in the FX Stack.
Terrence Walker
MacOS Monterey Version 12.6.2
