crashes....
djsolomon
crashes....
Post by djsolomon »
Anyone else finding that with two projects open there are more crashes with the 10.0 .18 ?
djsolomon
Re: crashes....
Debra, please always give us your information about your computer, its OS, etc...
On my side, I didn't notice this kind of problem.
Re: crashes....
no problem here, but yes, it's difficult to have an idea of what caused the crash.
djsolomon
Re: crashes....
Post by djsolomon »
Hi Elodie & Fabrice -I am on a PC running windows 7
I guess if other users are not having this problem
I may need to reinstall ... Also still the selection
Transform tool is causing crashes ...
My best debra
Re: crashes....
what version of the software are you using ? 10.0.18 ? 32 or 64 bits ?
djsolomon
Re: crashes....
Post by djsolomon »
Using latest update 10.0.18
32 bit
Re: crashes....
it should not crash then.
You can maybe try to make a new configuration in TVPaint.
djsolomon
Re: crashes....
Post by djsolomon »
ok - what do you mean by "a new configuration " ?
deinstall and then reinstal?
Re: crashes....
if you follow the "Edition Menu > Preferences Panel > Startup Tab", you should be able to activate the startup panel.
then restart TVPaint, and create a new config from the startup panel.
djsolomon
Re: crashes....
Post by djsolomon »
Thanks Fabrice!!!
will my tool bars be automatically deleted or will this just adjust the config?
my best debra
Re: crashes....
all depend if you create a new config or delete the previous one.
