How can I turn a faux-fixe loop into instances?
Soom
Post by Soom »
I did found a workaround by applying any FX on the frames I want, without really changing anything, but this is a bit of a hassle - is it possible to do just with one click?
Re: How can I turn a faux-fixe loop into instances?
If I need this, I create an empty layer on top of the loop, adjust the length, and merge it. It should be possible to put this into a script.
Soom
Post by Soom »
slowtiger wrote:If I need this, I create an empty layer on top of the loop, adjust the length, and merge it. It should be possible to put this into a script.
That's another workaround, but with an FX it's still faster...
