loop in loop
timson
loop in loop
Post by timson »
Hi,
I think this used to be possible: looping some loops.
or to use the tvpaint vocabulary: setting a faux-fixe of faux-fixes:
thanks
MacOSX 10.9.2 - 64bit - TVPAINT 10.5.7 PRO
Re: loop in loop
Nope, doesn't work.
Although you can set a larger FF after a short FF (including this), and it will work as desired, the looping of the first short FF is disabled then, it only plays the normal sequence.
What you can do, however, is to have a layer with a FF loop inside and set it to Repeat as a whole.
