Table only appear in rm 3 ...
thanks
djsolomon
ANYONE KNOW HOW TO ADD Tabs to all the rooms?????
Re: ANYONE KNOW HOW TO ADD Tabs to all the rooms?????
Sorry if "tabs" didn't explain... see image
The files i have open only appear in room 3 - not in the other rooms. How do i customize the rooms to include what files i have open
thanks
djsolomon
thanks
djsolomon
- tabs.PNG (17.94 KiB) Viewed 9832 times
that strip panel of icons across the top where the "tabs" of project names are displayed is called the MENU PANEL.
It's likely that one of two things have happened in the rooms where you can't see that strip panel:
1. In one of the other three other rooms click on the WINDOWS drop-down-menu-option next to Help and make sure that the Menu Panel is checked.
2. If the Menu Panel is checked and you still don't see the Menu's strip Panel icons where the "tabs" of open project names are visible, it is likely that the Menu Panel has been relocated into one of the scrolling side panel bins. To relocate the Menu Panel to its position across the top, just locate the Menu Panel somewhere in either of the side panel bins, LMB click and drag it all the way up to the top of the screen. When you release the mouse button, the Menu Panel will appear across the top again.
The unique mullti-character of the Menu Panel is discussed on page 1-2 and 1-3 in the manual.
yeap, it seems you've undocked the menu panel in the other rooms,
just re-dock it as Sven described above, and the project's tabs should reappear.
![Cool 8)](./images/smilies/icon_cool.gif)
thank you Sven and Zig...
much appreciated... this goes under the mysteries of tV paint...
NOTE to FABRICE : please consider separating these functions- people who work on multiple screens and want the menu panel in the center screens cannot pull it out and not loose the tabs...
thanks debra
thanks debra
