Tracker Panel
Mads Juul
Tracker Panel
Post by Mads Juul »
I want to share "Tracker Panel".
I made it under the supervision of Paul Fierlinger.
Use it to copy and paste the current Image out on Instance with the same name.
Remember you can manually set the name of the instance by double-click on the layer.
To use it:
select one or any number of frames and then press the "AUTO" button. This will rename all those instances.
Then after coloring the frame, press the "T" button, which will automatically track all the instances with the same name and paste the current image on them.
To streamline : Make a keyboard shortcut and assign it: Tracker_Panel_09:Tracker:Next Instance
Doing this will not change anything in the normal use of this key, that is, you can use it all the time you need to advance your cursor to the next instance. But if the instance happens to be one with an * before its name, it will paste the current image onto the instance on the same layer with the same name
To create a separate layer for coloring, click on the thumb of the original line drawing layer and use the white "x2" icon under the Layer tab of the Animator Panel. This will create an exact copy of the layer, including the changed numbers but clears the line drawings to ready the layer for coloring.
-Mads
Tracker_Panel_09.tvpx
(104 KiB) Downloaded 623 times
Léo
Re: Tracker Panel
Post by Léo »
Thank you for sharing, Mads :mrgreen:
Léo Fernandez
Wacom driver version 6.4.2-3
alfatoons
Re: Tracker Panel
Post by alfatoons »
:D
yalih
Re: Tracker Panel
Post by yalih »
hey there!
is it possible to rename multiple instances at once to have the same name? that could be VERY useful
thanks!
[vimeo]https://vimeo.com/yali[/vimeo]
Re: Tracker Panel
yalih wrote: 18 Oct 2019, 14:53 hey there!
thanks!
When you say rename multiple instances to have the same name , do you mean the same prefix ? Such as a series of drawings of a car ,
1, 2, 3, 4, 5, 6, 7, etc. and you want to rename them all as CAR-1, CAR-2, CAR-3 or C-1, C-2, C-3, C-4 , etc. Yes, that is possible
with the Mads Juul Tracker Panel . It is also possible with a built in option in TVPaint , if you right-click on the layer , choose Rename
I prefer using Mads' Tracker Panel for this , because it will respect the exposure and will number the instances to the frame . For example, if you have a series of drawings partially exposed ON 1's and partially exposed ON 2's , TVPaint will simply number the instances 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 ,16,17,18,19,20,21,22, consecutively , even if some of the drawings are exposed ON 2's , but Mads' Tracker Panel numbers them correctly as:
1 _ 3 _ 5 _ 7 _ 9 ,10, 11, 12, 13 _ 15_ 17_ 19_ 21_ , etc.
Here is how it looks using Mads Juul's Tracker Panel to rename instances with prefix -
Here is how it looks using TVPaint's built in Renamer -
yalih
Re: Tracker Panel
Post by yalih »
hey there! thanks for the detailed answer! but unfortunately, it is not what I meant
I want to apply the same name to many frames at once to that I will have this result:
A_A_A_A_A_A_A_B_B_B_B_B_B_B_C_C_C_C_C_C_C
for example- I would like to have instance 1-30 with the same name-A
instances 31-50 called have the same name- B
etc...
in TVP11 there is a feature to apply coloring squiggles to "all instances with the same name" (with CTG layer). that is why i need an easy way to rename a lot of instances at once.
thanks
yali
Re: Tracker Panel
yalih wrote: 09 Nov 2019, 13:44
Unfortunately , I think the only way to do that now is to manually rename each instance : A , A , A, A , A , etc.
I would imagine that someone who knows the TVPaint scripting language (George) could write a script to do what you want .
cgmodeler
Re: Tracker Panel
Post by cgmodeler »
yalih wrote: 09 Nov 2019, 13:44 hey there! thanks for the detailed answer! but unfortunately, it is not what I meant
etc...
thanks
yali
Hello, I modified Mads Juul version to make it work like that, to rename selected with the same prefix (prefijo), changed the variable so it wouldnt collide with mad's original script ,
SHIFT CLICK to write prefix, Ex "A"
select the instances you wanna rename the same,
run it,
change the prefix "B"
select instances
run it again
Hope it helps, I have no scripting experience but I did it to learn :)
RenameInstancesSame.tvpx
(5.5 KiB) Downloaded 485 times
www.cocoalopez.com
vimeo / 156794487
Desktop: TVP Pro 11.0.8 - 64bit Win 7 x64 48GB RAM - GTX1070 - Cintiq 27QHD Driver 6.3.29
Re: Tracker Panel
cgmodeler wrote: 12 Nov 2019, 06:21
Thank you for uploading your modified version. That's a very useful addition to the Mads Juul tracker panel.
yalih
Re: Tracker Panel
Post by yalih »
D.T. Nethery wrote: 12 Nov 2019, 19:40
its working!!! thank you soo much!!!
