paintbrush
paintbrush
paintbrush
making use of Luma invert Stamp to apply A and B colors
________________
open the paintbrush.zip file
save the paintbrush.bin file and paintbrush.data folder
in a "tvpaint custompanels" folder
then in tvpaint create a new custom panel tool bar
and import the paintbrush.bin file
voila...there you have the brush
enjoy
________________
enjoy
- this is what the actual brush looks like.
for its settings i've chosen to set anim behaviour to random - paintbrush.gif (378.47 KiB) Viewed 8187 times
- paintbrush.jpg (170.17 KiB) Viewed 8188 times
- paintbrush.ZIP
- (1.96 MiB) Downloaded 848 times
Yes super ! Very strange effects !
So is this possible to see a day the come back of Gradient cycling / shifting animation as old days Dpaint do ?
CG community :: www.tdt3d.com
it should be a .Zip file, extract it, and you should get a folder "paintbrush.data" and a "paintbrush.bin" file (see pict.);natali wrote:Also, when i download the brushes here, it comes as a .rar format (with three books). Is that right?
in tvpa, RMB on the Custom Panel icon, go to "load a new tool bar" and choose the .bin file.
- zip-extract.png (3.45 KiB) Viewed 7944 times
the icon doesn't really matter ...natali wrote:Yeah, thats right![]()
And i have done that, but the .bin file has a windows icon on it, instead of the blue icon on yours.
haven't you try the next step ?
ZigOtto wrote:...
in tvpa, RMB on the Custom Panel icon, go to "load a new tool bar", browse and choose the .bin file.
Hoi Natali,
mocht het met de laatse upgrade van tvpaint niet lukken
kan het ook nog zo:
laad het 'paintbrush.dip' bestand (hieronder) in tvp met 'load'
in het 'import Footage' scherm kies je de 'New Custombrush' tab (zie plaatje)
nu heb je hem als custombrush
stel vervolgens de goede settings in in het custom panel (zie andere plaatje)je kunt deze settings natuurlijk aanpassen naar je wensen.
shift beinvloed bijvoorbeeld hoeveel de brush mengt met bestaande kleuren.
succes!
_______________________________________________________________
Hi Natali,
in case upgrading doesn't do it
there is this option:
load the 'paintbrush.dip' file into tvp with 'load'
in the 'import footage' window choose 'new custombrush tab (see image)
now you have it as a custombrush
make the right settings (according to the second image)
you can adjust them to your liking offcourse
shift f.i. determens the ammount of mixing with other colors
good luck!
kan het ook nog zo:
succes!
Hi Natali,
good luck!
- paintbrush.dip
- (3.28 MiB) Downloaded 549 times
- paintbrush-settings.jpg (133.07 KiB) Viewed 7887 times
- paintbrush-laden.jpg (146.53 KiB) Viewed 7886 times
I apologize, I often mix up 'tvpaint' with 'mirage', so i wasnt sure what to call it.Patrice wrote:Hi Natali,
You need to have one the last version of TVP Animation to import Custom Panel. Which version have you? Can you give me the date writing in the "About" panel?
You speak about tvpaint/mirage... Have you TVP Animation or Mirage?
I own TVPaint 8.1.1.
