Distorted Video after Export
Lynnteressant
Post by Lynnteressant »
Hi,
I am having a lot of problems exporting my files in TVPaint. I very often get a distored video (see image below) It happens when I export using Quicktime Conversion, but not always (for example, when I use the settings MPEG-4, and check the box 'keyframe every: ...' it exports perfectly. Also H264 works, but also regularly glitches in the same fashion. Is this something common? And is there a solution for this?
My computer and TVPaint version:
Mac OS X 10.7.5 (Lion), 64 bit
TVPaint 10 (standard edition)
A screenshot to show what often happens:
Re: Distorted Video after Export
Check the drive you're exporting to. This looks like a damaged file system.
:shock: quite unusual ...
What happen if you export the same files, with the same settings, on an other computer ? Or when you export an image sequence or an "internal .avi" ?
It looks like damaged file created with a malfunctionning harddrive or processor.
