Hello Everyone,
I work with tvpaint 10 Pro, 32 bits on a Mac OSX 10.6.8
My problem is that when I use the selection tool as normal is not possible to do something in the area I've selected (draw, erase, allred floodfill etc. don't work). I figure out it is something that has to do with this stencil option, but when I disabled the stencil buttom then my selection is gone. And then when I deselect it (cmd + d ) the stencil icon keeps enabled and I can't draw or do something until I turn it off. The stencil icon on the layer is not activated.
It is strange that this happens in some documents because when I open other documents the selection tool works as normal (that means, you select something and you can apply diverse actions in the selected area).
It would be great if someone can help me solving this problem!
Thank you!!!
After selecting, I can`t do anyting in the selected area
Re: After selecting, I can`t do anyting in the selected area
Here's an example of how I use the free hand selection tool: If I need to resize just one part of a drawing, which happens often, such as the character's head, I draw the selection line around that area and then use the Transform tool to expand or contract that area. It never ceases to amaze me how little I need to use my pen after this is done.
"To clear the selection line I use the keyboard shortcut Shape Select: Clear All Stencil". This takes care of the stencil issue.
Thank you very much for your answer Paul.
I also use the selection tool as you do, I know it's very useful, but the problem is that sometimes it doesn't work and I don't know why.
For example I draw the selection area around the head of a character and then I try to paint it allred with the floodfill tool (of the sketch panel) and suddenly doesn't work anymore.
If I open a new project and make a test it works normal, but if I try in the project I was working on, it doesn´t work anymore.
I have the feeling that Im not explaining as good as I would like, but Im sure that this is happening to many people. And maybe the solution is pretty simple.
I Would be grateful if someone can help me.
As you are using a Mac OSX, why don't you use Quicktime to record your interface and show us what's going wrong in video ?
Fill in a selection:
- is the fill tool set to color?
- is it set to layer?
I think I know what is happening - we had this issue many times and we have figured it out: somewhere among all your layers, there is one (or more) layer that is marked as a stencil. When you use a transform tool, it automatically turns on the Stencil option, which, in it's turn, makes the "stenciled" layer also active and this prevents you to draw in all the areas that are not transparent on that particular layer. This usually happens by mistake and we already had discussions about the need to separate the Layer stencil function from the Selection stencil function - specifically to avoid this situation, that so many people encounter.
So, to solve this just click shortcut K - this will clear all stencils from all layers. If your shortcuts are reassigned and it doesn't work , you need to find Layer > Clear All Stencils in the keyboard shortcut configuration panel.
Hi everyone!
I'm a newbie here, and just started working in TVPaint Pro 11 (love it!), but I had the same problem with the selection tool ... I was wondering if it's been re-vamped in the new version?
Still, I'm glad I found this thread ... now I know what to do
Mary
Mary
Hello, welcome here !
No, it's still the same.I was wondering if it's been re-vamped in the new version?
My fault - It's really all very easy to find, thanks!
