Hi,
I was unable to assign a keystroke for a room. When I assign the keystroke it shows in the keyboard configuration window as I have assigned it, properly, but as soon as I close the configuration window, nothing happens when I press destined key. Then I open the keyboard configuration again, and surprise, the key is not assigned any more, although I am sure I did assign it, and I checked several times, always the same behavior. So far I experienced this only with rooms, but I will keep an eye on other key assignments since it is only my first day using TVP with Mac.
Room shortcut on 10.5.2 OSX
TV Paint 11.5.3 Windows 10
Re: Room shortcut on 10.5.2 OSX
I just made a test, using the version 10.5.2 64 bit on Mac OS 10.8.5 and I didn't have any problem.
If you go to Edit > Preferences > Startup => What is your startup configuration ?
It's "Remember last used configuration". I just did it again, after restart and update OS and it simply refuses to remember my shortcut, literally opening configure, assigning cmd 0 for room 1, it shows on the list
then I click OK, which brings me again on preferences window, if I click Configure again, this is what I get
note that cmd 0 now has empty assignment slot. How and why? I mean, it is not something to pull the hair for but still annoys a bit. To wrap it up, I will survive without it but - it is a bug. At least at my system. I hope you can reproduce it somehow -----
It's a bug on Mac OSX already in our to do list : you cannot assign any shortcut to cmd + pad.
=> http://forum.tvpaint.com/viewtopic.php?f=3&t=7121" onclick="window.open(this.href);return false;
It's probably it, thanks Elodie! Looking forward
