A couple of things...
Posted: 15 Oct 2013, 15:44
by JoHanna
Hi there!
Do you know if it's possible to slow down a clip on TVPaint? For example by 20% or something.
Also, is it possible to control the opacity and the color balance of a clip all at once on TVPaint or should that be done on AF?
Thank you so much! :-)
Johanna
Re: A couple of things...
Posted: 15 Oct 2013, 16:35
1. Grab the right-most handle of a clip and drag. A window pops up, selct "Stretch" and "Interpolate".
2. Can be done. See FX.
Posted: 15 Oct 2013, 19:26
by JoHanna
Thank you so much! The slowing is working already! :-)
Posted: 15 Oct 2013, 22:46
If you just want to preview what the clip plays like at a slower frame rate without interpolating the frames as Slowtiger suggests you can change the frame rate by clicking on the frames-per-second button on the play bar:
JoHanna wrote:Also, is it possible to control the opacity and the color balance of a clip all at once on TVPaint
As Slowtiger mentioned, this can be done with various options in the FX Stack -- Color .
TVPaint FX_Stack_ColorFX.jpg (53.71 KiB) Viewed 8924 times
