Hi everyone, I am very new to TVPaint and like all my friends and we never knew the big issue between Bahaus and TVPaint.
Anyway, I would like to use TV Paint instead of Mirage from now on and I am wondering if it is possible to replicate Mirage colour scheme on TV Paint.
In the preferences there s only 3 choices. Classic, Default and custom. I tried to fiddle around with the custom but gave up after half an hour.
Has anyone tried to do it or could we just download and install new colour schemes?
Olive
hi Olivier,
welcome to you, and happy new year!
regarding the color scheme, it's an old debat ...
some ones like it light, others rather dark, of course it's subject directly to the room where you are working,
in my case, I'm in a semi-obscurity ambiant (shadowy lighted room), so I'm naturally inclined to a dark UI.
if you are interrested, you can try my tvpa current (dark-grey) scheme, it's not the Mirage one, but it has near the same luminosity level,
how to try it :
first locate your config.ini file,
(on PC, it should be at C:/Documents and Settings/your_session_ID/Application Data/tvpaint animation/default/config.ini )
backup it somewhere else, then open it in a text editor, (f.i. WordPad)
scroll into the text till around the middle, the [SysColors] chapter, (46 lines),
cut it and replace it by the one below : then save your config.ini file (same place).
after that, you can try to launch tvpa, and see if it's fitting your desire.
if not, reverse the operation, by restauring your previous config file.
how to try it :
[SysColors]
mdesktopbackground=72 72 72
mgadgetaction=196 192 184
mgadgetactionover=250 250 190
mgadgetactionselected=250 250 190
mgadgetdefault=80 80 80
mgadgetdefaultinvert=80 80 80
mgadgetdefaultover=80 80 80
mgadgetdefaultselected=196 192 184
mgadgetdialog=196 192 184
mgadgetdialogover=190 190 190
mgadgetdialogselected=180 182 187
mgadgetdrag=149 151 158
mgadgetdragover=212 208 200
mgadgetdragselected=196 192 184
mgadgetelementbehavior=68 70 75
mgadgetelementcurrent=149 151 158
mgadgetelementdefault=80 82 88
mgadgetseparatordark=25 25 25
mgadgetseparatorlight=147 149 156
mgadgetslider=100 100 100
mgadgetsliderover=112 108 100
mgadgetsliderselected=136 139 147
mgadgetstat=168 170 158
mgadgetstatover=250 250 128
mgadgetstatselected=255 255 128
mgadgettabs=80 80 80
mgadgettabsover=60 65 68
mgadgettabsselected=60 65 68
mgadgettabstext=188 190 194
mgadgettabstextselected=250 250 190
mgadgettextbackground=108 111 119
mgadgettextinside=0 0 0
mgadgettextoutside=195 196 200
mgadgettextselectable=250 250 128
mmenushortcut=250 250 190
mreqbackground=80 80 80
mreqdragbar=52 54 56
mreqdragbarselected=60 65 68
mreqoutlineindark=25 25 32
mreqoutlineinlight=80 80 80
mreqoutlineout=5 5 5
mreqsystem1=168 170 176
mreqsystem2=128 131 139
mreqtitle=180 182 187
mzoombackground=63 64 69
