TVP project can't be open - Please Help
Posted: 28 Oct 2013, 11:26
by Margot Reumont
Hi,
I have a problem with project (2,2go) Tvp doesn't want to open it. I double click on it and nothing happen. Maybe something wrong with the RAM because the project is very full (lot of clip and sound)
Bonjour,
mon projet TVP ne veut plus s'ouvrir. Je l'ai fermé en sauvant hier soir, il pèse 2,2Go et ce matin,plus moyen de l'ouvrir. Rien ne se passe. Il veut bien ouvrir les versions précèdentes mais pas celle-ci.
Il y a beaucoup de clips et une piste son donc peut être que le projet est trop lourd à gérer. y a t il quelque chose à régler dans la mémoire cache?
Re: projet TVP ne veut plus s'ouvrir Please Help
Posted: 28 Oct 2013, 12:10
by Paul Fierlinger
What happens when you go into your TVP folder and double click on the TVP.exe? And what happens then, when that opens and you navigate to your hard drive to open your project?
Posted: 28 Oct 2013, 12:23
by Fabrice
2.2 Go is not that big, as we already saw much bigger files.
what if you load it from the software file menu ?
Re: TVP project can't be open - Please Help
Posted: 28 Oct 2013, 12:45
Can you eventually send us the file ?
Posted: 28 Oct 2013, 13:06
First test should always be to copy the file in question from one drive to another. Sometimes the copied file can be opened. Sometimes the copying itself doesn't work, in this case it's an error on file system level where TVP can't help.
Posted: 28 Oct 2013, 15:06
by Margot Reumont
This is the link for download the file on google drive :
https://drive.google.com/file/d/0BzJqkT ... sp=sharing" onclick="window.open(this.href);return false;
Posted: 28 Oct 2013, 15:17
We are downloading it. We will keep you posted if we can recover it :)
Posted: 28 Oct 2013, 15:57
by Thierry
Margot Reumont wrote:This is the link for download the file on google drive :
Hello Margot,
I have downloaded your file, and successfully opened it (it was only missing one or two audio files). I saved it, and will sent it to you tomorrow :)
Posted: 28 Oct 2013, 16:43
by Margot Reumont
Thanks ! I hope it will work.
Posted: 29 Oct 2013, 09:13
The file is available. Margot, I'll send you a PM with the link :)
