I have noticed that none of my layer attributes have been copied, after copy/pasting the whole layer to a new file. By attributes I mean image bookmarks and faux-fixe values.
I'm now on TVP Pro 10.0.11
Layer attributes not copied when copying to another file
Re: Layer attributes not copied when copying to another file
You should update, instead of using the old versions. For bugs or feature requests, it's always better to report them with an updated versionSoom wrote:I'm now on TVP Pro 10.0.11
Bookmarks are not layer's depending. You cannot copy past them.
I don't have any problems with the image mark panel or faux-fixe when I copy a layer and paste it into a new project
Yes, you are right, but unfortunately we cannot update in the studio, cause some other 3rd party software is not compatible with the new 10.5 update, which is a bummerElodie wrote:You should update, instead of using the old versions. For bugs or feature requests, it's always better to report them with an updated versionSoom wrote:I'm now on TVP Pro 10.0.11
Oh ? What do you mean ?cause some other 3rd party software is not compatible
If it's too private, don't hesitate to contact me by email
probably not true.Soom wrote: cause some other 3rd party software is not compatible with the new 10.5 update
The only big difference in the files structure is the .tvpp compression.
So you just have not to check the "compression" box in the preferences, when using the 10.5.x
Not a big deal.
Hmmm.. well Elodie has my pm with more detailsFabrice wrote:probably not true.Soom wrote: cause some other 3rd party software is not compatible with the new 10.5 update
Not a big deal.
I guess it's right, but it's not up to me... although maybe I can try it on my computer alone, and see if they have any problems...
well, we don't want you to disturb a whole production just to know if there would be problems.
Make sure to be able to continue working
Well, somebody has to shake those 3rdn party software people - I think they are in deep winter sleep ;o)Fabrice wrote:well, we don't want you to disturb a whole production just to know if there would be problems.
I can always to reinstall the older version - don't think it would be a big deal
