Page 1 of 2
exporting problem
Posted: 01 Nov 2013, 10:24
by Joost
In tvpaint 10, 32 bit version I always use the "enter" button to export my projects. In the 64bit version The enter buttons doesn't seem to work to export files...
Re: exporting problem
Posted: 01 Nov 2013, 10:35
by Paul Fierlinger
I assume you mean when you hit Enter after the Export panel has been opened. It works here both in 64 and 32.
Posted: 01 Nov 2013, 10:37
by Joost
Yes, That is what I mean Paul.
I think it is a mac problem then...
Posted: 01 Nov 2013, 12:03
by Paul Fierlinger
BTW, I programmed a key command at one point to open the export panel, followed by two "Enter" commands so that one key could just send the clip on its way without having to deal with the export panel at all. I had to stop using this method though because there were times (albeit rare) when TVP would mistakenly change my AVI format to PNG. YIKES! When that happens, export quickly fills a folder with multitudes (hundreds at times) of individual frames.
Posted: 06 Nov 2013, 11:07
by Joost
Can someone from the tvpaint team take a look at this problem?
Posted: 06 Nov 2013, 11:10
I don't have any problem with the 10.5.3 version.
Posted: 06 Nov 2013, 15:22
by Joost
strange...
Posted: 06 Nov 2013, 15:27
by Paul Fierlinger
Joost wrote:strange...
Have you tried today's TVP 10.5.3?
Posted: 06 Nov 2013, 19:11
Joost wrote:Yes, That is what I mean Paul.
I'm running TVPaint 10.5.3 (32bit) on a Macbook with OS 10.7 and the Enter/Return key works for export here.
Posted: 07 Jan 2014, 09:20
by Joost
I downloaded the last update ( tvpaint 10.5.4- 64 bit) and the enter button still doesn't work when I try to use it to export.
This is not a problem in the 32 bit version.
I'm using osx 10.9
Posted: 07 Jan 2014, 10:29
Both enter and return key do the job on my Mac. Sometimes I need to hit it twice, that's all.
Posted: 07 Jan 2014, 10:36
by Joost
It only works with me when I first select the export window.
In the 32 bit version I don't have to select this window.
Posted: 07 Jan 2014, 10:52
I don't have the problem either.
Can you check your keyboard assignments ?
Posted: 25 Jun 2014, 09:17
by Joost
I still have this problem.
When I'm rendering from the 32 bit version I can hit 'Enter' after I selected the folder in my browser and tvpaints starts to export. In the 64 bit version, I first have to select the export window to export. Since I have to render a lot of different image sequences, this takes a lot of extra time.
(The 'Enter' keyboard shortcut is the same in both versions.)
Any idea how I could fix this?
Posted: 25 Jun 2014, 09:42
Ok, I understand your problem.
-> in the bug tracker.
