Please show Out of Pegs size percentage, angle and position
Posted: 12 Nov 2013, 09:38
It would be very helpful to see detailed info for out of pegs transformations - this would make many processes much easier and faster...
TVPaint boards for technical support, requests and discussions about animation.
http://tvpaint.org/forum/
please can you give a concrete exemple of use of such informations (It makes sense, but I'm just curious !)Soom wrote:It would be very helpful to see detailed info for out of pegs transformations - this would make many processes much easier and faster...
One of the very common examples - if I have a character moving in perspective, and I need to insert an inbetween on, let's say - 1/3 or 1/2, or whatever position, so I need to know, at least approximate - the resize percentage. If there is rotation at the same time - I would want to know how much I rotate. Another example if I have a similar situation but with very subtle increments - let's say a character moves in perspective very very slow, and I need to inbetween tiny changes, it's really difficult to adjust those out of pegs now. especially if a character is small, and there is no way to set the center point or to have a rotation and transformation handles just available at your zoom level - I need to go far to the edge of the frame just to do something that I cannot even see, zoom in, check, go back, manipulate, zoom in again (I think this request for custom rotation center and available handles was done already before), and eventually after many manipulations, I even forget what did I actually manipulate at all. Often after manipulating one peg, I go to manipulate the other, then I go back to adjust the previous, but I have to guess again... This information is kind of a supplement to the other request about improving the out-of-pegs manipulation - I don't find it right now, but I know it was done.Fabrice wrote:please can you give a concrete exemple of use of such informations (It makes sense, but I'm just curious !)Soom wrote:It would be very helpful to see detailed info for out of pegs transformations - this would make many processes much easier and faster...
where would like to read the informations ? il the bottom info bar ?
