Loop the light table
Posted: 14 Nov 2013, 20:28
by neonnoodle
When I work on cycles, I would like to be able to have my first drawing seen in the light table when layer post behavior is set to "Repeat."
Right now I do this by breaking an instance in the post-layer area to create a copy of my first frame, but this leads to annoying frame-doubling when I play back.
Re: Loop the light table
Posted: 14 Nov 2013, 20:40
Uhm, it already works?
Set to repeat after and before the clip.
Posted: 14 Nov 2013, 21:00
by neonnoodle
Aha! :oops: Thank you for your guidance, slowtiger. I only had Repeat set for after.
Posted: 14 Nov 2013, 22:16
by neonnoodle
Hmm, there is still one issue -- I am using the light table in Image Mark mode, and it doesn't wrap around in this way.
