image mark question
momo
image mark question
Post by momo »
I just discovered the new shortcut for the different image mark colors: this is AMAZING! Thank you so much for adding this feature. :D
Now here is a little problem I have encountered:
I was trying to go through all my image marks (all colors) using a shortcut. But instead it goes through all the non marked images. I have found that if I click on the arrows (to go through all the image marks) in the Image mark panel it works properly.
Did I do something wrong or is it just a bug?
Cheers
Windows 7 64bit
TV paint Pro 10.5.3 64 bits
momo
Re: image mark question
Have you selected "Image Mark" in your Light Table?
This reminds me of a question I've been meaning to ask about the Image Mark Panel:
Is it possible to change the order of the colors in the Image Mark Panel ? I have two different Image Mark Panels . The larger one (on the right) is the one I prefer to use , but the order of colors is different than the order of colors in the Light Table image marks. (the smaller Image Mark Panel on the left is accessed via the Windows >Tools> Image Mark Panel ) . I can not find a way to edit the larger Image Mark Panel to change the order of the colors to match the Light Table image marks.
This is not a big problem , but I was curious whether it was possible to change the order of the colors in the larger Image Mark Panel ?
Image Mark Panel Order of Colors.jpg (86.85 KiB) Viewed 20817 times
Paul David, the one on the right is the old image mark panel, as a custom panel. Nobody is using it anymore.
If you prefer to use it as a custom panel, you just have to proceed with a selection > cut the brushes and paste them in a different order.
Strange. I thought it was David who had asked this question... but as time marches relentlessly on I can't tell anymore either. :oops:
*hum*
Sorry Paul :oops:
Phew, what a relief. :)
momo
Post by momo »
thanks for responses guys.
I have selected image mark on my light table but I still cannot go through all my images marks. Even after selecting default under image marks in the light table.
Its not super big problem since I can simple scrub through my animation instead and or use bookmarks for flipping between only keys and breakdowns.
My goal is simply to emulate the 1 2 3 flip and "rolling the pages" when working on paper. I am really trying to find the best way for speed so I can just press a couple of buttons and see what s going on.
cheers
momo
Could you send a screenshot with :
• your timeline
• your light table panel
• your image mark panel
all visible, please ?
momo, do you mean you want to know how to make your cursor jump from image mark to image mark when you press "next" or "previous"? That can't be done but it's an interesting idea. I wonder what any of the developers think about this.
That may be done if you assign some hotkeys ^^
Could you go further with this, Elodie? Which one would you start with? For an image mark assignment I see just Close, Open, and toggle.
See below :
This really works well -- so much to learn all the time. :)
momo
Post by momo »
Paul : thats exactly what I was trying to do. It is working BUT not if I try to flip just trough the marked images
• your timeline
here is the screenshot:
The instances are labelled:
K= key
BK= breakdown
IB= inbetween
To summarize:
Going from blue to blue works fine with assigned shortcuts as Elodie mentionned. The thing I am trying to do is going from color to color with one shortcut, in the exemple it would be blue green blue
(this way I could just see my keys and breakdowns which could be very useful when inbetweening)
momo
