Is it possible to assign hotkeys to my customized brushes?
Horloedgebleue
Post by Horloedgebleue »
I have created some customized brushes for the project I am working on.
If I can assign hotkeys to those brushes instead of having to click on them every time it would save a lot of time. Just wondering if there is a way to do such thing.
Thanks in advance!
Re: Is it possible to assign hotkeys to my customized brushe
if you have given any of those panels a name and have entered names for the brushes, you will find these in the right column of the keyboard shortcuts panel, from where you can assign any of the buttons to an available key in the left column.
To find the panel, type its name into the search window.
And to give a name to a brush, just right click on it > edit
give brush name.jpg (15.9 KiB) Viewed 7058 times
Horloedgebleue
It works! perfectly! Thank you!
The reason why I couldn't find my brushes in the shortcut panel was because I didn't name them.
