Color difference when exported
Psiscott
Post by Psiscott »
Hello All,
When i export my video, the color of the content that i import from photoshop is always different to that of the exported product, is there a way to fix this?
I attached two screenshots of before and after export.
Before Export (actual image)
Psiscott
Re: Color difference when exported
Post by Psiscott »
This is the after export picture
After Export
After Export
can you tell us more about what video format /codec compression did you use for your export ?
ematecki
Post by ematecki »
It may be a problem with the color profile of your PS files.
Be sure it is sRGB.
Psiscott
Post by Psiscott »
/here are the settings, of my photoshop file as well as the TVP paint
- I did try adjusting the file to sRGB but the option wasnt allowed in photoshop?- maybe its something else?
pohotshop file
pohotshop file
Screen Shot 2014-02-01 at 10.30.17 AM.png (47.94 KiB) Viewed 13031 times
project settings
project settings
Screen Shot 2014-02-01 at 10.22.55 AM.png (36.52 KiB) Viewed 13031 times
export settings
export settings
Screen Shot 2014-02-01 at 10.23.09 AM.png (37.78 KiB) Viewed 13031 times
Animark
Post by Animark »
You should have a look at the color-profile associated to your Photoshop document. If it is not sRGB, then that is probably the reason for the wrong colors in TVP. But are there wrong colors when working in TVP or only when you export the file?
Here is a screenshot where to look at the color profile in PS. (Sorry, a only have a german PS.)
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Psiscott wrote:... When i export my video, the color of the content that i import from photoshop ...
- to clarify what's your workflow, do you use : a) PS first + export > import into TVPA,
or b) TVPA first + export > import into PS ?
- your photoshop screengrab is about image size, not image format (?),
- if you're in b) case, export in AVI uncompressed RGB24
