Tvpaint Pro crashes
Robobob
Tvpaint Pro crashes
Post by Robobob »
Hello guys. Until recently everything worked great but just now Tvpaint Pro doesn't seem to work anymore. I'm working with the 64-bit version on Mavericks on an iMac. I keep getting the same message asking me if i want to reopen tvpaint after it crashed. When i click reopen it seems to crash again and if i don't reopen it nothing happens. Help....
Robobob
Re: Tvpaint Pro crashes
Post by Robobob »
Ok so I downloaded the 32bit version and this one seems to work as normal. At least no more Reopen/Crash bug happening. But the 64 bit version should just function properly on Mavericks right? All is good for now at least :)
Welcome here!
If you had a crash because of a configuration or interface's bug, each time you start tvpaint, it crashes again, as the config is bugging.
Close tvpaint and click on your finder. Click on "go to" top menu and hit "alt" to display the library. In the library, delete "tvp animation 10 pro" folder. Then, start tvpaint.
Btw, dont forget to update your license to the 10.5.5 version ;)
Robobob
Post by Robobob »
Thanks Elodie for the welcome as well! For some reason it works without problems now I was just about to try what you suggested but it wasn't necessary. Good to know for the next time. I updated to 10.5.5 also :D
