Icons have disappeared
Posted: 26 Feb 2014, 11:56
by LorenzoBE
Hello there,
Me again I feel that I've been pretty unlucky recently with TV paint. My new bug is now affecting my icons on the right hand side of the interface. I have since restarted my computer several times, hoping it would fix the issue.
Here is a picture of what I'm talking about. It already started in 10.5.4 so I upgraded to 10.5.5 but then got an error 1336 message. The two things are probably not linked as the icons started to display like this before the upgrade.
I am working on Windows 7 64 bit
Two: Intel XEON E5530 @2.4GHz processors
12 gb of ram
http://www.imageupload.co.uk/images/201 ... roblem.jpg
http://www.imageupload.co.uk/images/201 ... elprob.jpg
Thank you for your help.
Lorenzo
Re: Icons have disappeared
Posted: 26 Feb 2014, 13:31
by Soom
The second one is not related to TVPaint - it's a Sentinel Protection driver installation (for your dongle). If you had this working well with the previous version, and if you can run TVPaint without it asking for dongle -ignore it - you don't have to install the driver again.
As for TVPaint - I never saw a bug like this, but you can try and check your icons in the folder, where TVPaint keeps them. on my machine it's at c:\Users\(your_user)\AppData\Roaming\tvp animation 10 pro\default\icons\
See if they are there. if not - maybe somehow they got deleted, if yes - TVPaint lost link to them. you might want to try to reinstall TVPaint copmletely from scratch - it means to uninstall TVPaint first, clean your registry, restart, and install TVPaint again. if you are not sure how to do all that, don't try it - try more simple way of just reinstalling first.
Posted: 26 Feb 2014, 15:09
by LorenzoBE
Thanks Soom! I did need to clean the registry, but now it's all back to normal again after reinstalling it. I have no idea why it happened. Happy now though!
Posted: 19 Aug 2021, 15:41
by krycekuva
all the icons on the righten side panel disappeared. the buttons remain, but they are solid grey. i can click and they function, but i cant use them since i dont know what functions they have.
i already tried uninstalling and reinstalling the program several times. even installing a newer version. i also deleted the registry. after uninstalling the program. am i missing something? is there something else i can do?
thank u very much in advance.
D.
Posted: 19 Aug 2021, 15:56
by Xavier
krycekuva wrote: ↑19 Aug 2021, 15:41
D.
Before anything -->
we need your informations
Posted: 19 Aug 2021, 16:56
by krycekuva
true dat, sorry.
Hello there,
my pc is a laptop, 2,5 Ghz, 32 GB RAN, with 64 bit OS. Windows 10 Home.
i'm using a wacom intuos 5 touch m with Tvpaint 11
out of nowhere all the icons disappeared. the keys are still there, but they are solid grey. once i click them i do get the functions. they just dont show what they are. so its difficult to guess what button to click. i took a picture of the current situation, but uploading it it doesnt seem to turn upright, regardless one can see what i mean.
i tried unistalling the program and reinstalling it again. it keeps the previous presents so i assume even after uninstalling it, and installing a newer version , the registry remains and probable therefore the icons remain lost. is there anyway to fix this bug?
best regards and thanks in advance,
D.
https://ibb.co/WBbz0ZH
Posted: 20 Aug 2021, 09:02
by Dean
Hello, I think someone from your studio contacted me about this yesterday (I recognize the screenshot). I sent them an updated version of the Tool Presets panel to see if this one worked for you.
Posted: 20 Aug 2021, 12:03
by Xavier
krycekuva wrote: ↑19 Aug 2021, 16:56
Windows 10 Home.
It's possible that due to a filesystem corruption, your configuration was altered. It can happen on Windows if your computer had a powercut, or if you turned off your computer without using the "Start->Shutdown" menu.
Try this : close TVPaint, then hit WIN+R and type %APPDATA% (or just type %APPDATA% in the file explorer).
In this directory you should have a subfolder named "tvp animation 11" or "tvp animation 11 pro". If you don't need to save your settings then delete this folder and restart TVPaint.
Otherwise, if you need to keep your settings, at first do a backup of this folder. Then try to locate the file named "config.ini" and open it in an editor : find the "[ToolBoxList]" section and remove its content (remove [ToolBoxList] and all the lines below, until the next [section]).
Posted: 28 Aug 2021, 23:11
by krycekuva
hey there, first and foremost i wanted to thank you for the help. i ended up going a different route. i had to completely uninstall the software and then install it again. at some point it asked me if i wanted to delete all info and i said yes. after i installed it again, the connections were there and i can see the rest of the icons. maybe this will help someone in the future, it is still working for me..
thanx again!
Posted: 30 Aug 2021, 11:43
by Xavier
krycekuva wrote: ↑28 Aug 2021, 23:11
Yes, if you tick the checkbox then the TVPaint uninstaller will also remove the files in the %APPDATA% folder
