hi not sure if this is an error or what but i've just made 2 custom panels one for the chinese brushes and one for the pencils that are on the shared cntents pages...both work no problem but they will not work with each other...
if i start a session and use the chinese brushes they work fine...but if i then use some of the pencils the chinese brushes not longer work as they should, i have to quit tv paint and restart tv paint to make them work...but again if it want pencils then swap back the chinese brushes refuse to work as they should..they are sorta dotted and faint...
any ideas?
update..if i select a custom brush on my tool bin..then select the chinese brush it works....
i'm thinking this is my user error somewhere!...need to buy a printer to print out the tv paint manual!...or are you making a printed one available for purchase anytime soon?
custom panel errors
Re: custom panel errors
hi cresshead,cresshead wrote:...they are sorta dotted and faint...
can you grab and post here the tools-panel when it occures?
Hi Cresshead,
We have fixed the Chinese Brush CP and upload a new one in the topic dedicated to the Chinese Brush. The older was tweaked by hand and doesn't define all the connections causing the data storage issue when you were changing the current brush.
Normally, you should be able to use it and change the current brush as many times as you want without any problem now
nope, still broken....
i think it's me but don't know what to do to fix it
here's my demo of the error
[techsmith video codec]
-deleted video now it's fixed!-
i've tried deleting the panel....exiting tv paint..rebooting tv paint and adding the panel back..still same...
do i need to exit windows for this to take effect?
IS the download the current fixed one???
http://www.tvpaint.com/forum/download.php?id=835
'fixed rar'
'fixed rar'
chinese brush CP fixed
hi Steve,cresshead wrote:i've tried deleting the panel....exiting tv paint..rebooting tv paint and adding the panel back..still same...
'fixed rar'
try to unzip and to import this ChineseBrushFixed.bin,
I hope it will fix your brush reset problem .
ps: if it works, don't forget to save your config when leaving tvpa.
- ChineseBrushFixed.zip
- (54.21 KiB) Downloaded 1481 times
