Select and transform mutiple layers
boufertus1
Post by boufertus1 »
Hi
I am a TV newbie and i just can't seem to work out how to select all frames in multiple layers, then transform them all at the same time. Sorry but any help would be greatly appreciated. I guess it's something to do with grouping layers together but i still can't quite work it out. Many thanks!
Re: Select and transform mutiple layers
You just can't select several images on separated layers. :)
boufertus1 wrote:Hi
To apply the same amount of transformation on each layer select the images on the first layer , transform using the Transform Tool, hit Return/Enter to apply.
Now select the images on the next layer and hit Return again to apply the same transformation .
And repeat for however many layers you want to apply the transformation on.
boufertus1
ok! thanks :)
alicecool199
Post by alicecool199 »
I have the same problem.
I am using TV Paint 10.5 pro. When I select all the images of a layer and select apply on "all layers", then press enter, most images of all layers are transformed correctly, but some images just can't transform. Some of them are the first few images of that layer, while other images on the same layer all transformed. I am very confused about this.
There are so many confusions. Even I tried the method you said, it's not working
    I'd use the key framer for this. It'll do all layers at the same time and you can save the .bin if you ever need to redo it or slightly change it.
    Soom
    Post by Soom »
    alicecool199 wrote:Hello,
    This sounds a bit weird - please write down exactly your steps, or better - post a screenshot.
    Basically, if you want to apply the same transformation on one or more frames on a layer, you just need to select the necessary frames and transform ONCE. You can also transform one drawing, and then apply the same transformation on any other drawing by pressing Enter. This will repeat the last transformation.
    The way I understand this is the need to shift the positioning (and/or size etc.) of all frames on all layers by the same increment.
