auto break instance question
furushil
Post by furushil »
I have a sequence on 2s and want to paste a brush in place on several instances. I select the instances and paste in place but TVPaint breaks the instances so that the sequence is on 1s.
The same thing happens when I want to clear some instances in a sequence (on 2s). When I select the section and hit backspace TVPaint breaks the instances.
The auto break instance option in the program is off so I don't know why it is doing that.
Does anyone know how I can clear or paste without breaking the instances?
I know that you could mark some frames delete one exposure, paste the brush and then add one exposure again but it is not a good solution for me.
Re: auto break instance question
- to clear without breaking instance(s), use the "Clear Instance" button from the Animator Panel
(the one with a white square as icon) ;
- to Paste-in-Place a customBrush on several instances without breaking them, well, afaik, we have actually
2 ways, the easiest consists to embed these following 2 commands in a custom button :
Tools: Custom Brush Stamp in Place
Layers: Recompute Exposures
of cource, button assignable to a hotkey .
the other way is script based button,
tell me if you're interested, the script works fine here, but I can't guarantee for others
(computer/OS/tvpa versions/...)
furushil
Post by furushil »
ZigOtto wrote:- to clear without breaking instance(s), use the "Clear Instance" button from the Animator Panel
This is somehow not working for me. When I select 4 frames with 2 instances hold for 2 frames and click on the white square, it breaks the instances and I get 4 instances.
I try to check and uncheck the "auto break instance" option (Image->Instances->auto break instances) but it has no difference.
Unfortunately, I cannot use your other suggestion. I have to paste something very often and it is always a different brush (cut-brush).
furushil wrote:This is somehow not working for me. When I select 4 frames with 2 instances hold for 2 frames and click on the white square, it breaks the instances and I get 4 instances.
can you check your "white square" button by RMB-edit ...
the embedded command should be
tv_cmd heads tv_clear
if not, LMB-clic on the line, Type Script's Command ... and copy/paste the command above,
name it f.i. "Clear Instances", then assign it to your Backspace Key.
furushil wrote:... Unfortunately, I cannot use your other suggestion. I have to paste something very often and it is always a different brush (cut-brush).
have you created the custom button as I suggested in my previous post ?
once done and assigned to a hotkey, and whatever your custombrush and the frequency you'll use it,
this [Paste-in-Place+Recompute] command should work for any tvpaint user,
... or am I missing something in your specific workflow ...?
alternatively, you can get the same result without creating this custom button,
directly assign the 2 commands to a choosen free hotkey,
(Preference/ Keyboard Shorts Configure ... assign command1 + Ctrl-assign command2)
furushil
Post by furushil »
ZigOtto wrote: can you check your "white square" button by RMB-edit ...
ok, I checked that and my panel said this:
Bildschirmfoto 2014-04-13 um 13.17.15.png (17.24 KiB) Viewed 21565 times
so I made a new button with your code and it worked, thank you!
I am actually really scared of code :oops: because I think I could break the whole program or the program will run slower if I do something wrong.
I misunderstood you and thought you told me to assign the code to a custom brush not button.Now I tried your paste in place solution but the "Recompute Exposures" seems to get rid of the selected instances. When I hit the button the instances disappear.
furushil
Post by furushil »
I tried out the clear instance button again and realized that this is not a good solution for me.
Because now it always only clears the heads.
Let me explain:
I think the "clear the instance" button and "paste in place" (and other things) should be dependent on the "auto break instances" setting (Image->Instances->auto break instances). I always use the shortcut for "auto break instances" because sometimes I need to break them and sometimes not.
If I embed the command "tv_cmd heads tv_clear" it just switches the setting and it means that I would need two different buttons, one with clear the instances and break them and one with clear the heads.
Wouldn' t it be just logical to make everything depend on the auto break setting?
furushil wrote:...
yes, agreed, and the [auto-break Instance] behavior have been debated 1 year ago or so,
... particularily about the Transform tool behavior, which had changed from V9.x to v10.x
viewtopic.php?f=21&t=6705&start=15
I think (I hope ?) this request is already on the "To Do" list of the dev. team,
[Clear] and [Stamp-in-Place] shoud work in respect of the user's AutoBreak Setting as well,
and of course feel free to add your voice to this (important to my eyes) feature request thread. :)
for the time being, you have to set 2 different hotkeys, one breaking, the other not breaking,
f.i., Backspace to "Clear&Break", Shift Backspace to "Clear without Breaking",
in my worflow, I am personally using at 99% the "Clear-on-Heads-only" command, so I need only one shortkey,
and when I (rarely) need to Clear&break, I just have to do one more clic on the "Exposure Break" button of the Animator Panel,
or to hit my [Layer: Exposure Break] shortkey.
furushil
Post by furushil »
Ok, I see that it has been discussed before.
Maybe both threads can be merged then.
I also think the "auto break instance" setting should "rule them all".
a students just asked me: he wants the free transform to also break the instance,
why is it that only the pan breaks but transform and warp don't "listen" to the autobreak setting?
sorry if its a double question i haven't much time to dive in the thread
#edit#
well... i just did dive in and its a little confronting to see the state of my memory :? :wink:
but it seems the request still stands
yes, we still have something in the todo list about breaking instances with the transform tool (& other tools).
we didn't forget it.
Fabrice wrote:yes, we still have something in the todo list about breaking instances with the transform tool (& other tools).
8)... and please, don't forget "& other tools", such as "Clear" or "Stamp-in-Place",
which should work "by default" in respect of the user "AutoBreak" setting,
(as long as the user decides differently). :)
nothing to do with the Auto-Beak setting, but about Stamp-in-Place,
I've noticed something I consider as a misbehavior :
- cut a custombrush,
- go to another frame in the timeline and [Stamp-in-Place] it,
- [Undo], select a range of frames and [Re-Apply]
unfortunately, it doesn't stamp the current custombrush in place along the selected range of frames ...
imo, it should do exactly as it does when we stamp it "manually" (with 1 LMB-clic in the project preview).
yes, I was referring to those ones, among others.
