apply the current image on the instances with the same name
What a name I couldn't even search for this function, because it's so long.
But never mind that, there is something funny with this possibly very useful function.
It works fine if I use one layer on a project. Everything goes as it should. But If I add one layer on top, button doesn't work anymore. If I add +15 layers, it starts working again, but it adds the changes to all the frames. Not just on the named.
Bug? Clues? Already asked?
Re: apply the current image on the instances with the same n
huh ? I don't have any problem...
Can you record this and send us the video ?
hei Elodie,
I recorder a tutorial, but it seems to take some time to export it. I'll send it tomorrow.
Ok, here is the weird behaviour. Hopefully you can follow this.
Ok, thank you Kari for this video, that's clearer !
Wow, I didn't reproduce exactly your bug, but had a different one : when I apply the change on instance 1, instance 3 is not changed, but instance 2 is ^^"
2nd try : I reproduce your bug.
Okaaaay, let's to do list it !
Perfect, thanks!
Hello Kari !
The problem is fixed. As it depends on a George script, no need to wait for the next TVPaint release.
Just destroy your current Animation Panel (right click > make editable / right click again > this panel > delete)
Then, download the Animator below and drag it / drop it in TVPaint. Force Re-install and enjoy
- animator-panel-fix.tvpx
- (1.76 MiB) Downloaded 974 times
Impressive response time And thanks alot, it seems to be working as it should, good job!
Clone instance,...
Hello TVPaint users.
Anybody knows if it is possible to sort of "update" a drawing(clone) in the time line.
Let´s say On drawing(Instance) number 10 I decide to change something, but the same drawing(Instance) is repeated on frame 20. Is there a easy way to update this drawing(Instance) or do I have to erase
,Copy ,Paste the drawing?
Thanks in advance!
Thanks in advance!
Re: Clone instance,...
this can be done in certain versions of TVP. What's yours? Or to find out directly, look at the Animator Panel; under "Instance" do you see a green icon called, "Apply the current image on the instances with the same name"?
Hey Paul My version is:
V10 Pro.
I´m a new commer to TvPaint.
And thank you for responding to my question:)
V10 Pro.
Right I found it. !! Thank you very much!:)
You can find a plugin Madsjul put together to streamline the process, right here:
Once you install the tvpx in TVPaint you can find corresponding key commands in your key command panel.
http://forum.tvpaint.com/viewtopic.php? ... nel#p64046" onclick="window.open(this.href);return false;
If you decide to do this, let me know and I can walk you through a further trick how to completely atomize the process.
Hey Paul
Thanks again. It is 3 am now and I will try to look at it when I wake up.
Looks very good.
Thanks!
Looks very good.
Thanks!
