How to transform multiple frames and keep it position?
Nekomimi
Post by Nekomimi »
Hello, I'm a new user, so pardon me if I break any rules.
I have a problem with my animation. I imported scanned frames and I would like to resize them all at the same time. But when I do, the images change positions, and when played, it isn't a perfect loop anymore, but all the images "jump", because the image size is different for each frame.
Is there a way to prevent them all changing positions? Thanks in advance.
Re: How to transform multiple frames and keep it position?
We need more informations : How did you proceed to resize them all ?
Did you modifiy the whole project (using "Project > Modify Project") or did you change the size frame by frame using the transform tool ?
Btw, what is your software version ? Your OS ?
Nekomimi
Post by Nekomimi »
Fabrice wrote:Hello,
My version is TVP 9, using it on Windows.
I selected the frames, used the transform tool and pressed enter.
Ok, but I need to know the exact version : 9.x.y
Also, could you give a better description of the problem you have ?
Or post a screenshot ?
