put layers on center of canvas
Posted: 23 Apr 2014, 07:17
by Zetariver
Hello. I want to put layers on center of canvas like this video.
As you can see, all layers are placed differently,circle A is on x 100 y 200, circle B is on x 200 y 250,circle C is on x 300 y 0, etc.
So I need to check positions of all layers If I use keyframer.Seems It's not a best solution.
What is the best way to do that in TVPaint?
Re: put layers on center of canvas
Posted: 23 Apr 2014, 08:43
Hmmm, looks like we do not have such a feature to do it easily.
I move your topic in Feature request
Posted: 23 Apr 2014, 09:51
by Zetariver
OK. I will move them manually.
Posted: 23 Apr 2014, 09:54
Yes, sorry :/
Posted: 23 Apr 2014, 10:02
by furushil
I am not sure but if you import a png sequence all the pngs are aligned to the center of the canvas. So maybe if you have all circles as separate pngs you can import them into the project.
Posted: 23 Apr 2014, 10:47
It would work only if the circles were orignally a image sequence.
If they were drawn in TVPaint, it's then more complex.
Posted: 23 Apr 2014, 14:03
by Svengali
This might do what you want:
Create a new action in a custom panel, then cut and paste this script into the embed George script command.
Param none
ScriptName = "CenterAllLayers"
tv_GetWidth
Width = result
CenterX = Width / 2
tv_GetHeight
Height = result
CenterY = Height / 2
tv_LayerCurrentID
OriginalLayer = result
tv_LayerGetImage
OriginalImage = result
Counter = 0
LayerID = ""
For Counter = 0 to 1000
tv_LayerGetID Counter
LayerID = result
// tv_warn "counter = " Counter " layerid = " LayerID
ExitFlag = CMP(LayerID,"none")
IF ExitFlag == 1
EXIT
ELSE
tv_LayerSet LayerID
tv_BrushCut 0 0 Width Height 1 0
tv_BrushRestore Reset 1 Optimize 1
tv_Dot CenterX CenterY 0
END
END
tv_LayerSet OriginalLayer
tv_LayerImage OriginalImage
Posted: 23 Apr 2014, 14:11
Hmmm, I probably missed something because I can't use your script Svengali
Posted: 23 Apr 2014, 14:19
by Svengali
Elodie wrote:Hmmm, I probably missed something because I can't use your script Svengali
I just tried it and it seems to work. What do you get when you try it?
Posted: 23 Apr 2014, 15:49
Sorry I'm just too blond sometimes, I did a wrong copy paste
I confirm the script is working
This is a really great one, thank you Sven' !
Posted: 16 Dec 2014, 03:33
by Zetariver
Svengali wrote:This might do what you want:
Param none
tv_GetWidth
Width = result
CenterX = Width / 2
tv_GetHeight
Height = result
tv_LayerCurrentID
tv_LayerGetImage
Counter = 0
LayerID = ""
LayerID = result
IF ExitFlag == 1
EXIT
ELSE
tv_LayerSet LayerID
END
END
Sorry for my ridiculously late reply.
Your script works greatly. Thank you Svengali . I will use it.
