Problems importing movies into TVPaint
Olve
Post by Olve »
Suddenly I can't import avi or mov into TVPaint (10.5.3-64 bits). Nothing happens when I chose the file.
Anyone got a solution what could be wrong?
Animark
Re: Problems importing movies into TVPaint
Post by Animark »
try it with the 32bit version of TVPaint. Mostly it is an issue with Quicktime which is not working with the 64bit version.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Hello Olve,
The 64 bits version of TVPaint Animation cannot work with mov files, as the Quicktime libraries don't exist in 64 bits. As Animark said, you should use the 32 bits version if you really have to use mov files, or use another format.
The avi import should be working however.
I read that you have the 10.5.3 version of TVPaint Animation, you should update to the latest one, which is the 10.5.5, and see if you still can't import avi files.
ematecki
Post by ematecki »
Thierry wrote:The avi import should be working however.
Not on mac, AVIs are imported thru QT on macs...
Olve
Post by Olve »
Thanks for the reply.
I have updated to the latest version and I still have the same problems. Any other ideas?
- Can you play the movies?
- Can you import the movies into your video editor?
- Try renaming the files with 7bit-ASCII only (no special characters, no spaces)
ematecki
Post by ematecki »
Olve wrote:Thanks for the reply.
Are you on a Mac ?
If not, don't read what follows...
You *must* use the 32bit version to import this kind of files...
You can install both the 32 and 64 bits version at the same time, just rename one before installing the other one.
Olve
Post by Olve »
I'm on a PC. I installed the 32 bit version and it seems to be working fine now.
Thanks for all the help everyone! :)
Are you on a Mac ?
This has made me curious about something : I'm on a Mac (Mac OS 10.9) and I can import and play both .mov and .avi files in the 64 bit version of TVPaint. Is this because I have both 32bit and 64bit version of TVPaint installed ? Are you saying if I only had 64 bit version installed then it would not be able to import .mov files ?
ematecki
Post by ematecki »
D.T. Nethery wrote: This has made me curious about something : I'm on a Mac (Mac OS 10.9) and I can import and play both .mov and .avi files in the 64 bit version of TVPaint. Is this because I have both 32bit and 64bit version of TVPaint installed ?
No.
But ffmpeg (which we use for "replacing" QT in the 64 bits version) can read *some* mov files and *some* AVI files. Those with the most common non-proprietary codecs.
