Possible to save a custom brush in a panel without size?
Lukas
Post by Lukas »
Is it possible to save a custom brush in a panel without saving the brush size % value?
When I create a button for a brush while the size is set to 50% for example, draw a little bit, resize the brush to 75%, draw some more, use some other tool (airbrush for example) return to my custom brush, it resets the size to 50%. I don't want the size to reset each time I press the button, I'd want it to remain at 75%.
I don't want to use a shortcut 'Tools Brush > Custombrush' because I often use Cut brush to roughly animate some parts cut-out style before I clean. So that wouldn't work, because it wouldn't always return me to my brush, but would return me to some random body part sometimes.
So basically, I want a custom-brush button that doesn't have a size value.
Is it possible?
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Re: Possible to save a custom brush in a panel without size?
Wha about just setting the size you want before you save? Just a thought.
Lukas
Post by Lukas »
The point is I don't want 1 specific size.
So now I've got 5 different buttons for the same brush, and ... 5 different keyboard shortcuts.
Instead of just 1 button, and a resize shortcut.
  • LukasKrepel.nl
A brush can't be stored without a size. If you don't specify one, it will be 100%.
Lukas
Post by Lukas »
Allright, too bad. Thanks slowtiger
  • LukasKrepel.nl
