working slow
working slow
L2 Cache (per Core): 256 KB,L3 Cache: 6 MB,Memory: 8 GB
OS X version 10.9.2 ,64 bit,
TVPaint pro 64
I have a questions:
First at all I would like to understand what is wrong with the speed, I just do simple animation and have maybe 12 layers on timeline, my animation is max 3 min
I am very surprised that every time even if I only scroll my time line I get my computer " in thinking " mode, get the icon of rainbow circle rotating, Why? Should I change something in preferences?
The second question is about working on two screens, I would like to have timeline on one screen and windows when I draw in another screen I try to split it but it doesn't go... I could do it in aftereffect for example, is it possible in this program also?
The third question is about one window of light table panel that got stock in like in this photo:how shall I manage to move it?
thanks for your help
Kayaha
Re: working slow
Your first question has been discussed some days ago here: viewtopic.php?f=10&t=8191" onclick="window.open(this.href);return false;First at all I would like to understand what is wrong with the speed, I just do simple animation and have maybe 12 layers on timeline, my animation is max 3 min
3 minutes in a single file is a lot of frames. Your work file is probably bigger than 1GB. You have to split your project in smaller pieces.
What version of TVPaint are you using (10.X.X ?)
Re: working slow
hej, the project has 799 MB only
Re: working slow
I use TVPaint Animation Pro (10.5.5- 64 bits)
Re: working slow
You can go through the topic (the link that I posted above), maybe that helps.
When I open up the file in TVPaint standard 32bits there is no problem with scrolling through layers. But of course the preview in the 32bit version is slower.
Maybe someone else can comment on this.
If it helps, you can jump to a certain frame with the shortcut SHIFT+F (default).
Actually I have experienced the same thing. I am working on a 4700x2500px (100 frames) file right now and every time I scroll through the timeline the computer has to "think" too (for 1-2 seconds).I am very surprised that every time even if I only scroll my time line I get my computer " in thinking " mode, get the icon of rainbow circle rotating, Why?
Re: working slow
Do you mean it is better to switch to 32 bits version?
Re: working slow
You can try the 32bit version. On my computer the rainbow circle does not appear there.
In my case, I cannot use the 32bit version because the preview is not running smoothly there, so I rather have the 1-2 seconds rainbow circle.
I also would like to know why there is this difference between the two versions .
For how long does your rainbow circle spin? What is the dimension of your file in pixels?
Re: working slow
this discussion didn't find any solution as far as I see, and I can't believe that the project in such professional program cannot be bigger then 1600 frames!Your first question has been discussed some days ago here: viewtopic.php?f=10&t=8191
plus sound! That is so strange!
Re: working slow
The frame is little unusual 4000 x 4000 , and all sequence takes max 1600 frames, on about 12 layers but not every layer is fulled with frames. One layer with 1600 frames with animatik, and then small amounts of frames on different layers ( max 200 each).
Re: working slow
Wow! 4000x4000; 1,600 frames, 12 layers and all this at 24FPS.
That indeed is huge. To help us help you, could you explain the reasons you have chosen this size and frame rate?
Re: working slow
It is going to projected in big big tent... and it is not me who choose the format,
-but by the way all project is only 790 MB
Re: working slow
Hmmm... I tried to emulate your size and length with no problems. If you open another project and make a test copy of it, and then stretch this test project to fill the specs of your current, poorly performing one, will you have the same results? This would be a way to test if there is some thing in your current project that is slowing its performance down. Are you using a lot of colors which use paper? That's one element that is often a memory hog.
Re: working slow
No, I just use one colour, and make it very simple. Animatic is heavy, has almost 500mb bot that all what is heavy...
Re: working slow
furushilfurushil wrote:You can try the 32bit version. On my computer the rainbow circle does not appear there.
it takes sometimes 20 sec... I believe it must be some setting in preferences... this cannot be like that!
Re: working slow
ok, you are on Mac ...
a bug was recently found when using the "next/prev instance" shortcuts in Mac 64 bits, so the global speed might improve in the next version (planed soon).
Just try the 32 bits to see if it's better.
Otherwise, for the playback, something you could try too is to unactivate the proxy.
