No thumbnails in timeline after using "tv_LoadSequence"
Lukas
Post by Lukas »
When I import a sequence with tv_LoadSequence, it only shows the first and last image of the sequence in the thumbnails.
Is there a way to somehow update the frames in between? They don't show up when drawing in them either. I'm not sure what's going on. :(
Screen Shot 2014-05-21 at 16.17.41 .png (14.11 KiB) Viewed 4144 times
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Lukas
Re: No thumbnails in timeline after using "tv_LoadSequence"
Post by Lukas »
After importing a sequence I also want to use "tv_layerRecomputeExposure" but it tells me to load all dependencies.
How do I import a sequence with actually loading them into the project?
  • LukasKrepel.nl
have you checked on the "preload" option from the import panel ?
Mads Juul
Post by Mads Juul »
Lukas wrote:When I import a sequence with tv_LoadSequence, it only shows the first and last image of the sequence in the thumbnails.
You have to select Show Thumbnails in the layer menu (RMB click the layer).
I think for some reason this is not default when using tv_loadSequence. And I don't think it is possible to enable "Show Thumbnails" With George.
Lukas wrote:After importing a sequence I also want to use "tv_layerRecomputeExposure" but it tells me to load all dependencies.
I dont think it is possible to preload images with tv_loadSequence. maybe ias Zigotto says try import something manually and enable preload. and then see if tv_loadSequence is preloading afterwards.
It is not possible to Load all dependencies with george.
BUt remeber you can always load all dependencies amanually in the top project menu but I guess you know this.
I vaguely remeber I 5 years ago had the same issues with tv_loadSequences so I stopped using it.
-Mads
Lukas
Post by Lukas »
madsjuul wrote:I vaguely remeber I 5 years ago had the same issues with tv_loadSequences so I stopped using it.
Have you found an alternative way to import stuff into TVPaint?
I am writing a script to export animation from Anime Studio Pro and import it in seperate layers much like your TVPaint to After Effects script.
I can export seperate layers for character line art and colour from ASP, so it'll be easy to do boring slow animation in ASP and do crazy fun frame by frame stuff in TVP. Best of both worlds. I've got some brushes in ASP that match my TVP brushes almost 1:1, so I'm quite excited to get this working.
But this tv_LoadSequence stuff is kind of a bummer...
  • LukasKrepel.nl
Mads Juul
Post by Mads Juul »
There is several other ways.
You can use tv_readtextfile to get names of files in a folder.
Yoy can use tv_fileinfo to get width and height of image file so you can create a project with the right dimension
Then you can import each file with a While loop for instance and
Tv_loadImage
So I think it is possible to make an import script as you descibe
-Mads
Lukas
Post by Lukas »
Thank you!!
I'll try that :)
  • LukasKrepel.nl
Lukas
Post by Lukas »
I broke my head getting it to work, but it works :)
tv_LoadSequence is quite useful this way...
  • LukasKrepel.nl
Mads Juul
Post by Mads Juul »
Lukas wrote: tv_LoadSequence is quite useful this way...
Which way? How are you using tv_loadsequence?
Lukas
Post by Lukas »
Haha oops...
I meant to write: "tv_LoadSequence is not very useful this way..."
In the end I used tv_LoadImage, but it was a lot more work to get it working correctly.
  • LukasKrepel.nl
Mads Juul
Post by Mads Juul »
Lukas wrote: In the end I used tv_LoadImage, but it was a lot more work to get it working correctly.
:) Ok I understand . Yes it is more work. but at least it is possible. And tv_loadImage is more flexible maybe you at some point would need to do something You cannot do with loadSequence anyway.
FOr instance import images with different names in the same folder and time it frrom an EDL exported from premiere,
This is how I at a point got timing from Premiere to TVPaint.
But nice you made it work :)
Mads Juul
Post by Mads Juul »
Mads Juul wrote: I dont think it is possible to preload images with tv_loadSequence.
Hi Lucas
I just found out it is possible to preload images with tv_loadSequence. You just have to add "PRELOAD" at the end of the cammond like
tv_loadSequence filepath "PRELOAD"
I added it in the wiki
http://wiki.tvpaint.fr/index.php?title=Tv_LoadSequence" onclick="window.open(this.href);return false;
I also discovered there is a george function for loading dependencies of a layer
tv_layerloaddependencies layerID
http://wiki.tvpaint.fr/index.php?title= ... pendencies" onclick="window.open(this.href);return false;
Kind Regards Mads
Mads Juul
Post by Mads Juul »
After discovering that is actually is possible to preload a sequence with "tv_loadSequence", I stumbled on this thread from 2008
http://forum.tvpaint.com/viewtopic.php? ... it=preload" onclick="window.open(this.href);return false;
I was wondering about this question for the developers
Is it possible to enable/disable the layer option "Show Thumbnails" with George?
Kind Regards Mads
Mads Juul wrote:I was wondering about this question for the developers
It's not possible.
I'll add that in the todo-list :)
Mads Juul
Post by Mads Juul »
It's not possible.
thank you.
Maybe when using tv_loadSequence I think the show thumbnails should be enabled by default.
-Mads
