Delete exposure & Enter a value manualle
NathanOtano
Post by NathanOtano »
I'm doodling with some goerge script and have two questions
Is there a function to remove an exposure of an instance? I can use tv_Layercut but that's not really what i was expecting to do.
Can i enter a variable manually each time i run the script in my custom panel? For exemlpe if i want to add x exposures, i want to be able to choose the x each time i launch the button.
Nathan
NathanOtano
Re: Delete exposure & Enter a value manualle
Ok I found what i wanted for my second question, i just have to use tv_reqnum :)
NathanOtano wrote:Is there a function to remove an exposure of an instance? I can use tv_Layercut but that's not really what i was expecting to do.
Try tv_LayerCut which works on the current frame, current layer. Removes the current frame (exposures and finally the head) of the instance.
Mads Juul
Post by Mads Juul »
Svengali wrote: Try tv_LayerCut which works on the current frame, current layer. Removes the current frame (exposures and finally the head) of the instance.
It also works on current selection .Which you can set with
http://wiki.tvpaint.fr/index.php?title=Tv_LayerSelect
-Mads
NathanOtano
Thanks! So that's what i found. Glad to know that's good also for selection.
The only thing is that you have the images in your clipboard then and so you lose your previous copy/cut but that's ok for me. I think it can be corrected by some other script but i don't really need it.
