Wobbly line when sketching using TVPaint 10 pro edition
Smeerik
Post by Smeerik »
I'm having some issues now I use TVPaint 10 pro edition 64 bit
When i'm sketchting my line doesn't seem clear, when i draw a circle it seems wobbly. That is not the case in the standard edition i used.
this the circle i drew in pro
and this is a circle i drew in standard
Why does the pro version do that? i have an pc using windows 7 with 8 GB RAM memory
No other aplications running, it should work fine.
furushil
Re: Wobbly line when sketching using TVPaint 10 pro edition
Post by furushil »
In the menubar go to Windows->Settings->Shape Settings
and check the "smoothing" setting at the bottom
shape settings.png (15.01 KiB) Viewed 34997 times
Smeerik
Post by Smeerik »
Thanks but I know about the line smoother, but that does not work for sketching.
Both circles i drew without the line smoother. It just bothers me why it is diffrent from the standard edition.
just drawing in Pro feels slightly buggy compaired to standard edition.
furushil
Post by furushil »
I tried to draw many circles with the standard and pro version without line smoothing and I think you are right there is a slight difference.
It does not happen all the time in my case. I would say 1 out of 4 circles gets wobbly.
But you are right in the standard version it seems never to get wobbly.
I also tried to set the line smoothing to 10. In that case 1 out of 8 circles got wobbly in the pro version -but actually it is barely noticeable.
Does it happen with every circle that you draw?
Smeerik
Post by Smeerik »
It seems to happen more often if you are a little more zoomed out.
I sometimes like to see the complete drawing field as I draw to have more controle of my composition.
it's not just circle though its most lines i make. Its really distracting because i have to keep re-doing my lines.
Animark
Post by Animark »
That sounds really strange. Unfortunately I cannot compare by myself, but one difference between Pro and Standard is, that Standard is running only at 32 Bit. Maybe an idea to get closer to the problem.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Animark
Post by Animark »
OK, I compared between 32 and 64 bit Pro, but didn't noticed any difference. I also didn't got any wobbles - except my own natural line wobbeling, but not as our picture shows.
Smeerik
Post by Smeerik »
Weird... Well thanks for your help hopefully a solution will present it's self in time.
Do you have TVPaint 10.5.7 ? If you don't, please update your software.
Smeerik
Post by Smeerik »
I do, bought it 2 days ago, and i checked for updates, just to be sure. But there were none.
Please can you (un)check the subpixel/wintab preferences in TVPaint and restart TVPaint ?
Smeerik
Post by Smeerik »
I unchecked the boxes in preferences.
The lines seem to bee smother now, but now i cant use the sidebutton on my wacom pen anymore
and now there is a box that keeps apearing when i use the alt or ctrl key.
here is a screen grab:
Smeerik
Post by Smeerik »
Hey, i've seem to have found the problem.
WinTab was Checken and SubPixel was unchecked.
When I Checked them both, eveything seems to be working the way it should.
I was about to write you that suggestion.
Cool to see you found it 8)
Joost
Post by Joost »
Since a few days I have the same problem.
Can somebody tell me where I can find the subpixel/wintab preferences?
Thanks!
TVP Pro 11.7.1
