No F10 key in Configure Keyboard Shortcuts?
Sewie
Post by Sewie »
I just noticed that the 'Configure Keyboard Shortcuts' panel does not have the F10 key in it. It jumps from F9 to F11.
Is this supposed to be like that or is it an oversight on the developers part?
furushil
Re: No F10 key in Configure Keyboard Shortcuts?
Post by furushil »
Do you mean this panel ?
On my computer F10 is "Drawing Mode 09"
Sewie
Post by Sewie »
That's strange because it isn't present in my panel.
Looks like a small bug in the windows version.
EDIT: I just checked on another windows machine and it's the same; no F10.
hellofilms
Post by hellofilms »
No F10 here either. Running Windows.
Windows 11 - TVpaint 11.7.1(dec 5 2022) pro - Wacom cintique 24 Pro
There's a reason for that : the F-10 key is handled differently by the system than the other F-x keys. When F-10 is pressed, the default system behaviour is to "steal" the event for itself, which is not the case with the other F-x keys.
And changing Windows default behavior is not really recommanded.
So that's why there's no possibility to assign a shortcut to the F-10 key on Windows.
Sewie
Post by Sewie »
Okay. Thanks for enlightening us.
It's not a real problem but I thought I should point it out.
Is there a similar reason in Windows that any shortcut key action assigned to Control Enter is automatically assigned to Control J?
Soom
Post by Soom »
Thierry wrote:There's a reason for that : the F-10 key is handled differently by the system than the other F-x keys. When F-10 is pressed, the default system behaviour is to "steal" the event for itself, which is not the case with the other F-x keys.
??? I am working on Win XP and Win 7 for years, and never had any F key stealing anything to the system - I use F10 perfectly in any software... The only moment, when F keys are used for the system, is during the system startup - to invoke all kinds of startup behaviors - but never during normal work...
