BUG in 10.5.7 - FX Stack > Stylize > Erode
Bug Report:
TVP 10.5.7 , FX Stack > Stylize > Erode
Change the numbers for the parameters Width and Height in Erode FX by typing in the numbers (not using the slider arrows to adjust numbers) . If I type in more than three changes to the parameter values in Width and Height of Erode , then TVP 10.5.7 will CRASH.
This is on Mac OS 10.9.4 , TVP 10.5.7 64bits. (the same crashing behavior does not happen on TVP 10.5.7 32bits )
FX Stack - Erode.jpg (26.51 KiB) Viewed 6051 times
Re: BUG in 10.5.7 - FX Stack > Stylize > Erode
I'll look into it :)
Thanks.
It's really not a huge issue ... the easiest work-around is to just use the slider arrows to adjust the numbers in the Width and Height parameters . This does not cause any crashing. Using the slider arrows works fine.
